Top 10 NGAP Failures in Real 5G Networks (gNB ↔ AMF - N2 Interface)
1. NG Setup Failure
Example:
NGSetupFailure
Cause: misc.unspecified
Reason:
AMF rejects gNB connection.
Common Causes:
  • PLMN mismatch
  • TAC not configured in AMF
  • Unsupported gNB ID
  • AMF overload
Troubleshooting:
Verify PLMN and TAC configuration in AMF.
2. Initial UE Message Failure
Symptom:
Initial UE Message missing.
Cause:
gNB does not forward Registration Request to AMF.
Possible Reasons:
  • RRC failure
  • UE not reaching NAS layer
  • gNB configuration issue
Check sequence:
RRC Setup Complete → Initial UE Message.
3. Unknown UE NGAP ID
Example:
Error Indication
Cause: unknown-local-UE-NGAP-ID
Reason:
AMF cannot find UE context.
Common Causes:
  • UE context deleted in AMF
  • gNB restarted
  • SCTP session reset.
4. Authentication Failure
Example NAS message:
Cause: MAC failure
Possible Causes:
  • Wrong subscriber key
  • UDM/AUSF problem
  • SIM mismatch
Seen in packets:
Downlink NAS Transport → Authentication Request
Uplink NAS Transport → Authentication Failure.
5. Security Mode Failure
Example:
Security Mode Reject
Reason:
UE rejects security algorithms.
Possible Causes:
  • Ciphering mismatch
  • Integrity algorithm unsupported.
6. Initial Context Setup Failure
Example:
InitialContextSetupFailure
Cause: radioNetwork unspecified
Reason:
gNB cannot allocate resources for UE.
Possible Causes:
  • Radio resource shortage
  • QoS mismatch
  • Network slice not supported.
7. PDU Session Resource Setup Failure
Example:
PDUSessionResourceSetupFailure
Possible Causes:
  • SMF rejected session
  • UPF unreachable
  • Wrong DNN/APN configuration.
8. UE Context Release
Example:
UEContextReleaseCommand
Cause: radioConnectionWithUElost
Reason:
UE radio link lost.
Common Causes:
  • Poor signal
  • UE mobility
  • RRC failure.
9. SCTP Association Reset
Transport layer issue.
Examples:
SCTP ABORT
SCTP SHUTDOWN
Possible Causes:
  • gNB restart
  • AMF restart
  • Firewall issue.
10. Error Indication Message
Example:
ErrorIndication
Cause: protocol semantic-error
Possible Causes:
  • Vendor interoperability issue
  • Incorrect IE encoding
  • Unsupported optional fields.
Important Wireshark Filters
N2 Interface:
sctp.port == 38412
NGAP Only:
ngap
Errors:
ngap && ngap.Cause
Failure Impact
NG Setup Failure gNB cannot connect to AMF
Initial UE Message Reject UE cannot register
Authentication Failure UE authentication fails
Security Mode Failure Security negotiation fails
Initial Context Setup Failure UE context not created
PDU Session Setup Failure Data session fails
UE Context Release Session drops
Handover Failure Mobility issue
Paging Failure UE unreachable
SCTP Failure N2 connection down
