In PUCCH dynamic power control, when the TPC command in DCI 1_1 adjusts the power (up or down), after how many slots will this power change take effect?
Is this timing specified in any 3GPP documentation?
In my search for documentation, I found this: After 1 slot(dci 1_1) no more, and 3GPP especifications is 38213.
The uplink slot that immediately follows DCI 1_1 is where it will take effect.
In a sequence with 4 DL slots (e.g., DDDSUUDDDD), if a TPC command to increase or decrease power is received in the first DL slot via DCI 1_1, the adjustment will take effect at the next uplink opportunity, which occurs 4 slots later?
