The Problem Isn’t AI in 5G. It’s Your Data Foundation
Your 5G network can predict failures.
But your data layer isn’t ready to support it.
We often talk about AI-driven 5G:
Predictive analytics
Closed-loop automation
Self-optimizing networks
But in real deployments, the challenge isn’t the model.
It’s the data foundation behind it.
Across 5G Core and RAN, observability data comes in multiple forms:
:thought_balloon:Performance counters (PM/KPIs)
:thought_balloon:Events and alarms
:thought_balloon:Traces and session-level data
Packet captures
And most of it is:
:sparkles:Vendor-specific
:sparkles:Schema-inconsistent
:sparkles:Poorly correlated across network functions
Functions like NWDAF are designed to generate insights,
but they rely on structured and well-correlated inputs—not raw, fragmented telemetry.
So the real gap is here:
:backhand_index_pointing_right: Telemetry normalization and correlation before analytics
:magnifying_glass_tilted_left: What’s missing in most 5G deployments?
Common data models across NFs
End-to-end correlation (UE → RAN → Core)
Time-synchronized events (NTP/PTP alignment)
Unified ingestion pipelines for analytics systems
Without this:
:cross_mark: Predictions lack context
:cross_mark: Correlation breaks across layers
:cross_mark: Automation remains reactive
:rocket: Where modern observability fits in
Frameworks like OpenTelemetry introduce:
Standardized telemetry constructs (logs, metrics, traces)
Context propagation across services
Vendor-agnostic observability principles
But in telecom, this needs to coexist with 3GPP-defined interfaces and vendor telemetry, not replace them.
:light_bulb: The real shift
We don’t just need AI-native networks.
We need data-native architectures.
Because in 5G:
:backhand_index_pointing_right: Intelligence is only as good as the data pipeline feeding it
And that pipeline starts with: standardized, correlated, and context-rich telemetry
—not just more logs.
Curious to hear from the field: Are current 5G deployments investing enough in data engineering for AI?
Linkedin: :backhand_index_pointing_down:
