Hello Experts,
Can anyone assist to clear the fault below for test system command?
<Test system;
NOT ACCEPTED
FAULT CODE 1
ALL TEST INDIVIDUALS ARE OCCUPIED
Hello Experts,
<Test system;
NOT ACCEPTED
FAULT CODE 1
Hi, @King, you can end previous running test with END TEST; command. Another option is to look if there is any SAE that can be increased.
<end test;
NOT ACCEPTED
FAULT CODE 26
TEST COMMAND IS NOT PRECEDED BY THE INITIATING COMMAND 'TEST'
This is the feedback from END TEST;
Check all terminals for running test. Active terminals are in IOSTP;
You need to release the device on which the command “test system” was sent.
For that you print the alarms with allip; first, you will get the below printout:
TEST SYSTEM (1) ACTIVATED FROM AD-305
then you do:
<IOCMI:IO2=AD-305;
IOCMI:IO2=AD-305;
:END TEST;
IOCME;
END OF COMMAND READING IO=AD-304 END
The device is released after that.
Hello!
You can released “test system” by connecting to the AD-xxx on which test system; was activated (see in the allip printout) and give ‘end test;’ command there.
To connect specified AD-xxx:
mml -d (or -ad) AD-xxx
