TDD Frame Structure and Frame Start Offset
Hi all,
When coordinating C-band between operators in the same country, the TDD frame structure should be the same. Additionally, the frame start offset should also align, correct?
For example, if two operators each have a contiguous 100 MHz block and use the same frame structure (7D-1S-2U), but one sets the frame start offset to 0 ms and the other to 3 ms, this misalignment would cause interference between them.
Could you confirm if this understanding is correct? Thank you!
Wall golden tape design.
Hello Sir , what is the frameoffset parameter in Ericsson Vendor to set it 3ms ?
thank you
