Sys info message information
Hello,
Is there a way to know the RS power, Cell power and PA/PB for a cell when checking the Sys info message from the UE perspective?
Check from oss dsp cell last paramerer is max transmit power lst pdschcfg rs power and pb and lstcelldlpdschpa u will get pa.
You can see from oss
In Huawei and I think sib2 from dt analysis.
Thank you @P_N, but I want to know from the UE side…
Ah! let me check.
It does not seems to have it in sys2.
Check under PDSCH configuration common in SIB2.
DL reference signal EPRE : 19 dBm
P b : 1
From your SIB2.
Yes, Thanks @gkreddy!
