SW Error on Ericsson Baseband with NR TDD
Hello Experts!
Has anyone faced a “SW Error (Contact Next Level of Support)” on Baseband 6630(SW22) when operating NR NSA TDD MidBand RRU4418 (3 cells) together with LTE FDD (12 cells) in mixed mode?
Any insights on root cause and possible workaround or fix?
Good day.
You need to align the software in the RRU and BB, for example, by reloading the BB and RRU one after the other with a hard test. It’s better to upgrade to the same software with the RRU already connected.
SW error alarm can appear anywhere under any setup.
Maybe you can try with another software release or go back to factory settings. Maybe
RACH parametrs issue
really RACH parameters?
I’ve never seen a “SW Error” solved without a restartunit. Or maybe a software upgrade can restartunit
The parameter for type random access and cell range was not specified
