Electro magnetic spectrum has multiple ranges like x ray, gamma ray, radio waves, ultra violet, infrared, visible light…
Light is one form of electro magnetic radiation.
Light wave consists of electric field and magnetic field 90 degree shifted.
Light waves used currently in multiple systems (mobile communication, utilities… ) to transport Traffic.
Light waves can transport traffic over ultra long distance with ultra high capacity.
Optical spectrum focus on ultra violet, infrared, visible light.
Visible light where we can see the colors, with in the range between 400 nm to 700 nm.
Optical communication based mainly on infrared.
We use infrared to transport Traffic with WDM technology, infrared has main 6 bands as defined by ITU.
ITU: International Telecommunication Union.
O , S , E , C , L , U starting from 1260 nm to 1675 nm.
Most common used bands are C & L bands for DWDM technology.
The reason is that C & L has the lowest attenuation coefficient and can efficiently transport traffic for ultra long distances.
C band has 3 types:
- Basic C band support 80 channel
- Extended C band support 96 channel
- Super C band support 120 channel
- To increase the system capacity, we can use the below :
- Use mixed C & L
- Use flex grid
- Use higher modulation orders
- Use super C band
- Modulation can be used QPSK, 16 QAM, PDM…
