Hi All,
I have one question related to srs port configuration for 5G:
Possible SRS port configuration is 1, 2 and 4 port.
Based on which condition network decide port configuration?
Is it directly related to Uplink Mimo or some other paramters as well?
Brother,
Basically Sounding Reference Signal (SRS) resource sets are configured by the higher layer parameter “SRS-ResourceSet”.
“SRS-Resources” can be configured or set to (BeamManagement/semi-static/semi-persistent/aperodic/periodic) by higher layer parameter SRS called “Resourcetype” and “usage”(‘codebook’ or ‘antennaSwitching’)
This calculation done on NW side based on the UE capability(as an example ‘1T2R’, ‘2T4R’,
‘1T4R’, ‘1T4R/2T4R’, ‘1T=1R’, ‘2T=2R’, or ‘4T=4R’) that is indicating UE supports 1 2 or 4 ports.
Its depend on how the calculation done on NW side based on the above SRS-Resources configuration with including UL MIMO.
Below is the rrc-reconfig message just for reference. many parameters are there, few major parameters are like resourcetype,usage,P0, resourceId, noofSRS-ports,transmissionComb,offset etc.
srs-Config
SetupRelease : setup
Setup
srs-ResourceSetToAddModList :
[0 ] :
srs-ResourceSetId : 1
srs-ResourceIdList :
[0 ] : 1
resourceType : aperiodic
aperiodicSRS-ResourceTrigger : 1
usage : codebook
p0 : -110
srs-ResourceToAddModList :
[0 ] :
srs-ResourceId : 1
nrofSRS-Ports : port1
transmissionComb : n2
combOffset-n2 : 0
cyclicShift-n2 : 0
startPosition : 0
nrofSymbols : n1
repetitionFactor : n1
freqDomainPosition : 4
freqDomainShift : 0
c-SRS : 0
b-SRS : 0
b-hop : 0
groupOrSequenceHopping : neither
sequenceId : 1
