Most people think mobile networks are built from towers and “5G equipment”.
But the real limiting resource is spectrum.
Spectrum is the invisible slice of radio “real estate” that carriers use to move data through the air. And just like real estate, location and size matter: the same amount of spectrum can behave very differently depending on the frequency band.
A simple way to remember it:
Low-band travels far and penetrates buildings well → great for coverage
Mid-band is the sweet spot → strong coverage + capacity
High-band (mmWave) delivers huge peak speeds → but over short distances and with obstacles in the way
So when someone says “my 5G is faster” (or “why is it worse?”), it’s often less about the “G” and more about which spectrum the network is using in that place, at that moment - plus how many people are sharing it.
Spectrum decisions shape everything we care about in telecom: coverage maps, indoor experience, rural connectivity, and whether networks can keep up with exploding traffic.
If you had to pick one: would you prioritize coverage everywhere or maximum speed in hotspots?
