Yes @RFSpecialist , could you elaborate more?
Is it related cov scenario of the antenna,like scen default,1-16?
It was transmitted under the same cell basically, and I can see the changing is in 20s in some part.
If scenario is the factor then it could not be happened in the same sector. Isn’t?
It is on same sector same cell.
Yes, it is. Also UE received it within the gap 20s between each other.
Coverage scenario is cell parameter and needs cell restart.
So, it means there is chance this is bug from the system?
Sorry, no idea.
Parameters is NRDUCellTrpBeam.CoverageScenario.
Do you have any specific mapping N1-N2 to cov scen?
What I get from your exp the sync of the cov scen is where the scen has higher vertical beam so then it will have 2-2, then where the scen with low vertical the it will give 4-1?
Isn’t?
But still if that is the reason then why it got changed in the same scen?
Let me reset and let’s see.
Yes it is like this.
I have seen from other vendors n1-n2 like 8-2
Meaning 32 csi-rs ports that is a very sharp beam for pdsch
Yups…I know in Ericsson they have introduced it.
How about Huawei? Any clue?
