Hello Experts,
What is the differece between Spatial Diversity and Spatial Multiplexing - MIMO?
Can someone clarify please?
The main difference between Diversity and Multiplexing is:
Spatial Diversity is a technique to overcome probability of error, P_e
Spatial Multiplexing is a technique to increase data throughput
Spatial Diversity:
We all know transmitted data in wireless is received through multipath propagation i.e., Fading
If the channel is worse, P_e is high this implies channel is in deep fade
Transmission of multiple copies of the same information over independent channels, thereby reduces the chance of information loss
Even if one or more channels are in deep fade remaining channels will decode data correctly
Spatial Diversity can be employed in 3 ways
- Transmit Diversity
- Receive Diversity
- Switching Diversity
Spatial Multiplexing:
Transmission of multiple copies of the different information over independent channels i.e., transmitting information in parallel
Since transmitting multiple parallel streams in space through different spatial modes it is known as Spatial Multiplexing
Spatial Multiplexing is employed when P_e < Threshold, this implies channels are good and not in deep fade
Integration of Diversity and Multiplexing:
Whenever P_e > Threshold we have to adjust it by implementing spatial diversity technique
What is different between Spatial Multiplexing and Transmit Diversity in MIMO system?
Here you have a good explanation:
In short:
- Spatial: send different data from multiple antennas, so increase your throughput.
- Diversity: send same data from multiple antennas, increase data correction rate.
