SMS Over Diameter Failure - SM-Enumerated-Delivery-Failure-Cause: EQUIPMENT_NOT_SM-EQUIPPED (2)
Hello Everyone.
It has been weeks I am trying to figure out an issue with my cluster for SMS Over Diameter.
As some of my UEs dont support VoLTE, as alternative we want to enable SMS Over Diameter for them, yet, after configuring everything needed on the MME, still MT fails.
MO From UE To network works perfeclty.
SMSoDiameter > MME > SMSC > IMS > UE (Works Perfectly)
SMSoDimaeter > MME > SMSC > MME > UE (Fails before MME tries any NAS Message or paging)
S6c is works fine, MME details are retrieved from the HSS for the destination UE.
the MME silently drops the message and returns (SM-Enumerated-Delivery-Failure-Cause: EQUIPMENT_NOT_SM-EQUIPPED (2))
Status:
MME Is registered for SMS
HSS has registered it.
Teleservice ts21 and ts22 is added
MME announces support for SMS in MME
SC Address is correct (TBCD) and it is correct.
MME is TBCD as well
TP-ID seems to be correct
…0 0000 = The SM-AL protocol being used between the SME and the MS: 0
TP-DCS seems to be good
00.. … = Coding Group Bits: General Data Coding indication (0)
Special case, GSM 7 bit default alphabet
Username is OK, it is IMSI
extended DRX is not enabled, as it is a phone
phone capability is set to support SMS MT
I followed the process that handles the SGD interface, yet, I couldnt find a clue.
I have enabled debugging and have checked all the logs , so far, I cant see any logs related to this issue.
if I make any other changes, then I can see the failure in the MME, but not for this case.
I have taken packet capture on the S1 interface, nothign happens.
I have also taken packet capture of the phone RF module and logs, nothing arrives there as well (the MME doesnt even try to deliver it)
It feels like that I am missing something in the initial attach proceure that barrs this user from receiving SMS.
Note: no service related to SMS is barred. and it is a combined attach.
any ideas that might help? or if anyone can share a working packet capture?
thanks
This is because you have combined attached I suppose you have SGs interface also since SGs interface is CS network UE gives CS network priorirty and listening to VLR GT.SGd is considered PS network so UE rejecting that MT SM delivery.Why your MO is getting success is I think MME terminating the Submit SM towards MSC/VLR(SGs) and routing it to SGd.
Hi @VijayHI
Thank you for your reply.
In my case, I guess i need to force combined attach, as I dont have SGs interface, and SGd is preferred.
By the way, my network is 4G only.
Thanks
