Hi,
Which are tha main differences from Scheduled throughput and application throughput?
Which is higher?
Scheduled one, in MAC layer.
More control bits are there which are transparent for the user who perceive the application layer throughput.
So scheduled is much more from application correct
No! Lower you get in the stack, more overhead you add, thus, larger the payload, larger is the throughput!
https://www.sharetechnote.com/html/Throughput.html
“First he should not expect to get the same number on IP traffic monitor as 3GPP spec sheet shows, because what 3GPP spec sheets shows is the physical layer throughput, not the IP layer throughput. Between physical layer and IP layer, there are various kinds of overhead getting inserted. So it is natural to see a little bit less throughput on IP traffic monitor than the number on 3GPP spec sheets.”
