Resource Activation Timeout – Unable to Allocate Radio Resources for S4C1
Hi everyone,
Does anyone know how I can clean or resolve the following error?
SP7081> st cell
250625-10:45:58-0300 172.25.171.9 24.0f MSRBS_NODE_MODEL_23.Q2_608.28193.116_7219 stopfile=/tmp/32519
Number of Failed login attempt(s): 0
Last Successful login: 2025-06-25 13:42:06 from 10.216.155.18
$ssh_pid = 7214
Connected to 172.25.171.9
(SubNetwork=ONRM_ROOT_MO_R,SubNetwork=WCDMA,SubNetwork=TSP,SubNetwork=RadioNodes,MeContext=SP7081,ManagedElement=SP7081)
Proxy  | Admin State | Oper. State | MO
99     | UNLOCKED    | ENABLED     | NodeBFunction=1, NodeBLocalCellGroup=1
100    | UNLOCKED    | DISABLED    | NodeBFunction=1, NodeBLocalCellGroup=1, NodeBLocalCell=S4C1
103    | UNLOCKED    | ENABLED     | NodeBFunction=1, NodeBLocalCellGroup=1, NodeBLocalCell=S5C1
104    | -           | ENABLED     | NodeBFunction=1, NodeBLocalCellGroup=1, NodeBLocalCell=S5C1, CellResources=1
112    | UNLOCKED    | ENABLED     | NodeBFunction=1, NodeBLocalCellGroup=1, NodeBLocalCell=S6C1
113    | -           | ENABLED     | NodeBFunction=1, NodeBLocalCellGroup=1, NodeBLocalCell=S6C1, CellResources=1
Total: 6 MOs
SP7081> alt
250625-11:09:16-0300 172.25.171.9 24.0f MSRBS_NODE_MODEL_23.Q2_608.28193.116_7219 stopfile=/tmp/20026
Collecting Alarms...
Date & Time (UTC)   S Specific Problem                    MO (AdditionalText/PC, AI)
2025-06-18 19:59:02 m Link Failure                        RiLink=4 (No signal detected (link start time-out). Near end port:FieldReplaceableUnit=1,RiPort=D (transportType=NOT_SET))
2025-06-18 20:05:14 M Resource Activation Timeout         NodeBLocalCellGroup=1,NodeBLocalCell=S4C1 (Unable to allocate radio resources.)
>>> Total: 2 Alarms (0 Critical, 1 Major)
Thanks in advance for any guidance or tips!
Hello, @Mistolejo !
Check physical connection for RiLink=4, because you can see alarm with “No signal detected” text. May be need to replace SFP (recommends replace on both side - BB and RRU).
