Hi,
If you’ve got a back-to-back user agent or a RTP relay in your IMS your reporting may see two calls for every one, for example the call leg through the IMS to the TAS and then a new Call-ID coming from the TAS to the other networks, this would cause you to see 2 calls for every 1 call made, and the counters mismatching.
