QoS Flow Debugging in 5G: Why Voice Isn’t Always Priority
You’d expect voice in 5G to always get top priority, right?
But in many real-world 5G SA networks, voice QoE still drops — even when coverage and bandwidth look perfect.
The hidden reason?
:backhand_index_pointing_right: The QoS flow isn’t doing what it’s supposed to.
Quick Recap: What’s a QoS Flow?
  • In 4G EPC, QoS was managed through bearers (default and dedicated).
  • In 5G Core, it evolved into QoS Flows — each identified by a QFI (QoS Flow Identifier) and governed by 5QI values.
But here’s the catch — these flows only work if the SMF, UPF, and PCF all stay in sync:
  • SMF defines the QoS rules.
  • PCF enforces the policy (priority, GBR, ARP).
  • UPF executes the packet-level treatment.
If any of those fail to align → your voice packets are treated like best-effort data.
Common QoS Flow Issues in 5G
  1. Missing 5QI Mapping → SIP/RTP flows assigned wrong 5QI (e.g., 9 instead of 1 or 5).
  2. PCF Policy Not Applied → Policy rules not pushed to SMF.
  3. UPF Rule Conflict → Incorrect PDR/FAR pair causing packet drop.
  4. QoS Re-establishment Failure → UE moves cells, but flow isn’t recreated.
  5. GBR Bearer Not Honored → Voice marked as GBR but handled as non-GBR.
KPIs to Watch
  • VoNR MOS / Jitter / Packet Loss
  • 5QI Flow Creation Success Rate
  • PDU Session Modification Success Rate
  • QoS Re-establishment Ratio
When QoS is broken, you’ll see normal data KPIs fine — but voice QoE plummets.
Troubleshooting Checklist
  • Verify QFI and 5QI assignments from SMF logs.
  • Check PCF for missing IMS policy enforcement.
  • Trace UPF PDRs/FARs → ensure SIP and RTP traffic are prioritized.
  • Monitor QoS setup events during mobility (handover or reattach).
Takeaway:
  • In 5G, QoS isn’t automatic — it’s negotiated, signaled, and enforced dynamically.
  • If the SMF, PCF, and UPF don’t talk perfectly, even premium voice flows end up behaving like background data.
:backhand_index_pointing_right: Have you seen QoS-related voice degradation in your 5G network?
Was it a missing 5QI, policy issue, or UPF enforcement bug?
