I want any help as I facing a problem when I want to formate Baseband which has upgrade (R13F43) by logging into baseband by emergency Access IP (https://169.254.2.2/ea.html) I did not found Boardrestore Bottom so I can’t format it
I have the same problem. Please help.
set SystemFunctions=1,SecM=1,LocalAccessM=1 emergencyRestore 1
Thank you, I will check tomorrow and write the result
Hello
BBU connected and format problem solved.
It is possible to connect and download and format with Firefox.
