Hello all.
In case of 10 MHz LTE uplink which uses SC-OFDMA, assuming a UE Pmax of 23 dBm, what will be the power per subcarrier?
Hello all.
23 dBm - 10log10(600) = - 4.78 dBm
Ok.
So you are assuming 600 sub-carriers.
But won’t it be like one sub-carrier per RB in SC-OFDMA, so 50 carriers at max?
No.
That’s not how SCFDMA works.
You call it a single carrier because you are doing dft before ofdm.
Also, you mostly keep power per subcarrier as constant.
If you don’t transmit data on 5 MHz then also power on remaining subcarriers will be same as -4.78 dBm.
