Hi All.
Does anyone working for operator have statistics how much OTTs are advanced comparing to VoLTE?
I mean, how many million of minutes are spent on OTT daily and how many millions of minutes are spent on VoLTE daily?
Here are some WhatsApp statistics globally from last year:
I know for sure OTTs are overtaking VoLTE in terms of millions of minutes spent by users.
All teenagers use just OTTs they seldom use VoLTE.
A good link here: Whatsapp Statistics 2023 — How Many People Use Whatsapp
By the way, do you know that MOS/POLQA for WhatsApp is same or even better than VoLTE?
This would have been impossible some years ago but WhatsApp improved a lot.
Despite the fact that VoLTE is GBR bearer while WhatsApp is non-GBR bearer.
WhatsApp and other OTTs on Meta(Facebook / Instagram) in general has clear edge on the voice quality over other applications.
Should not be the case over cellular.
VoLTE is GBR with guaranteed resources so should score higher.
RFSpecialist:
VoLTE MOS degrades due to AMR codecs…
I have clearly felt so! Meta Platforms are way better!
I am not comparing the score at the more, neither have done. Just sharing the subscriber perception.
Hainm
December 12, 2022, 10:16pm
#6
I don’t think Whatapp voice call quality better than VoLTE.
Weechat voice quality is very good.
Do you have statistic of Whatapp & VoLTE call duration?
GBR has application when there is congestion, at normal scenarios there is no any difference between GBR bearer or non-GBR. just from QCI point of view there is difference.
For MOS, I think codec has more affect.
