Most engineers first encounter OTN rates as a table of numbers.
ODU0
ODU1
ODU2
ODU3
ODU4
It feels like memorization.
It is not.
š¢š§š” šæš®šš²š š®šæš² š®šÆš¼šš šššæšš°šššæš².
Once you understand the structure, the numbers make sense.
š§šµš² šš®šš¶š° šš±š²š®
OTN defines fixed-rate containers called š¢ššØšø.
Each ODUk represents a specific payload capacity.
Think of them as standardized transport boxes.
Here are the core ones you will see in modern networks:
These are fixed containers.
They do not float. They do not burst. They are deterministic.
š¢ššØšø šš¼š»šš®š¶š»š²šæ šš¶š²šæš®šæš°šµš
ODUk containers are scalable building blocks.
Higher containers can carry multiple lower containers through multiplexing.
Example:
⢠Multiple š¢ššØš¬ can fit into š¢ššØš®
⢠Multiple š¢ššØš® can be mapped into š¢ššØš°
This is structured aggregation, not statistical sharing.
Figure 5.1: ODUk Container Hierarchy
šš¹š²š š¶šÆš¹š² ššæš¶š± š®š»š± š¢ššØš³š¹š²š
Modern OTN goes further with š¢ššØš³š¹š²š .
ODUflex allows bandwidth to be allocated in smaller time-slot increments.
Instead of being locked to rigid 10G or 100G blocks, you can create:
⢠25G services
⢠75G services
⢠Custom bandwidth profiles
But here is the important distinction:
Even with ODUflex, bandwidth is still explicitly assigned.
It is not shared dynamically like Ethernet.
š¢ššØš³š¹š²š šš®š»š±šš¶š±ššµ šš¹š¹š¼š°š®šš¶š¼š»
ODUflex slices time slots inside a higher-rate container.
Each slice is controlled.
Each slice is monitored.
Each slice is deterministic.
Figure 5.2: ODUFlex Bandwidth Allocation
š„š®šš²š š®šæš² š”š¼š ššÆš¼šš š¦š½š²š²š±
This is where many engineers misunderstand OTN.
OTN rates are not primarily about speed.
They are about:
ā¢ š¦ššæšš°šššæš²
ā¢ š¦š°š®š¹š®šÆš¶š¹š¶šš
ā¢ š šš¹šš¶š½š¹š²š š¶š»š“ šÆš¼šš»š±š®šæš¶š²š
ā¢ š¦š²šæšš¶š°š² š¶š±š²š»šš¶šš
When you design a backbone, you are not asking:
How fast is this link?
You are asking:
How are services structured inside this link?
That question leads you to the correct ODU level.
šš¶š»š®š¹ š š²š»šš®š¹ š š¼š±š²š¹
š¢ššØšø š®šæš² š³š¶š š²š± š°š¼š»šš®š¶š»š²šæš. š¢ššØš³š¹š²š š¶š š°š¼š»ššæš¼š¹š¹š²š± š³š¹š²š š¶šÆš¶š¹š¶šš.
Both operate under deterministic transport rules.
That is the difference between:
š§šæš®š»šš½š¼šæš š²š»š“š¶š»š²š²šæš¶š»š“
and
š§šæš®š³š³š¶š° š²š»š“š¶š»š²š²šæš¶š»š“
In š£š®šæš š², we will go deeper into š¢š§š” šŗšš¹šš¶š½š¹š²š š¶š»š“ and time-slot architecture, where the real design decisions happen.
