OTN Learning Series Part 4: ODU, OTU, OPU Explained Simply
In the previous parts, we clarified:
• š—Ŗš—µš˜† š—¢š—§š—” š—²š˜…š—¶š˜€š˜š˜€
• š—Ŗš—µš—®š˜ š—¢š—§š—” š—æš—²š—®š—¹š—¹š˜† š—¶š˜€
• š—›š—¼š˜„ š—¶š˜ š—±š—¶š—³š—³š—²š—æš˜€ š—³š—æš—¼š—ŗ š—˜š˜š—µš—²š—æš—»š—²š˜
Now we open the box.
š—¢š—§š—” š—¶š˜€ š—»š—¼š˜ š—® š˜€š—¶š—»š—“š—¹š—² š—¹š—®š˜†š—²š—æ. It is a structured system with three distinct roles:
š—¢š—£š—Ø š—¢š——š—Ø š—¢š—§š—Ø
Understanding these three correctly changes how you design transport networks.
š—¢š—£š—Ø — š—£š—®š˜†š—¹š—¼š—®š—± š—”š—±š—®š—½š˜š—®š˜š—¶š—¼š—»
š—¢š—£š—Ø stands for Optical Payload Unit.
Its job is simple.
It takes a client signal and adapts it into an OTN container.
Think of OPU as:
• The interface translator
• The rate aligner
• The payload wrapper
It does not manage services. It does not enforce protection.
It simply prepares the signal for transport.
Figure 4.1
Figure 4.1: OPU adapts client signals into structured OTN payload containers.
If you inject:
• 10GbE
• 100GbE
• SONET
OPU aligns and maps it into a usable structure inside OTN.
Nothing more. Nothing less.
š—¢š——š—Ø — š—¦š—²š—æš˜ƒš—¶š—°š—² š—–š—¼š—»š˜š—®š—¶š—»š—²š—æ
š—¢š——š—Ø stands for Optical Data Unit.
This is where transport engineering actually happens.
š—¢š——š—Ø š—¶š˜€ š˜š—µš—² š˜€š—²š—æš˜ƒš—¶š—°š—² š—¹š—®š˜†š—²š—æ.
At the ODU level, you get:
• š—šš—æš—¼š—¼š—ŗš—¶š—»š—“
• š— š—¼š—»š—¶š˜š—¼š—æš—¶š—»š—“
• š—£š—æš—¼š˜š—²š—°š˜š—¶š—¼š—»
• š—™š—®š˜‚š—¹š˜ š—œš˜€š—¼š—¹š—®š˜š—¶š—¼š—»
When people say OTN provides determinism, they are usually talking about the ODU layer.
Figure 4.2
Figure 4.2: ODU is where services are switched, monitored, and protected.
This is where:
• 10 x 10G becomes 1 x 100G
• Failure is localized
• SLA boundaries are enforced
If you remember one thing from this article, remember this:
š—¦š—²š—æš˜ƒš—¶š—°š—² š—²š—»š—“š—¶š—»š—²š—²š—æš—¶š—»š—“ š—µš—®š—½š—½š—²š—»š˜€ š—®š˜ š—¢š——š—Ø.
š—¢š—§š—Ø — š—§š—æš—®š—»š˜€š—ŗš—¶š˜€š˜€š—¶š—¼š—» š—Ÿš—®š˜†š—²š—æ
š—¢š—§š—Ø stands for Optical Transport Unit.
This is the physical transmission wrapper.
OTU handles:
• š—™š—˜š—–
• š—§š—æš—®š—»š˜€š—ŗš—¶š˜€š˜€š—¶š—¼š—» š—³š—æš—®š—ŗš—¶š—»š—“
• š—¦š—¶š—“š—»š—®š—¹ š—¶š—»š˜š—²š—“š—æš—¶š˜š˜†
This layer cares about:
• Bit errors
• Optical reach
• Signal quality
It does not care about SLAs.
Figure 4.3
Figure 4.3: OTU protects the signal over the fiber using FEC and framing.
Think of OTU as the shield between:
š—¦š—²š—æš˜ƒš—¶š—°š—² š—¹š—¼š—“š—¶š—° and š—¢š—½š˜š—¶š—°š—®š—¹ š—½š—µš˜†š˜€š—¶š—°š˜€
š—£š˜‚š˜š˜š—¶š—»š—“ š—œš˜ š—§š—¼š—“š—²š˜š—µš—²š—æ
Here is the clean mental model.
š—¢š—£š—Ø š—½š—æš—²š—½š—®š—æš—²š˜€.
š—¢š——š—Ø š—ŗš—®š—»š—®š—“š—²š˜€.
š—¢š—§š—Ø š—±š—²š—¹š—¶š˜ƒš—²š—æš˜€.
This separation is why OTN scales cleanly in the core.
Each layer has one responsibility.
No ambiguity.
š—§š—µš—² š—žš—²š˜† š—§š—®š—øš—²š—®š˜„š—®š˜†
If you mix these roles mentally, your designs will feel unstable.
If you separate them correctly, OTN becomes very simple.
š—¢š—£š—Ø š—¶š˜€ š—®š—±š—®š—½š˜š—®š˜š—¶š—¼š—».
š—¢š——š—Ø š—¶š˜€ š˜€š—²š—æš˜ƒš—¶š—°š—² š—°š—¼š—»š˜š—æš—¼š—¹.
š—¢š—§š—Ø š—¶š˜€ š—½š—µš˜†š˜€š—¶š—°š—®š—¹ š—±š—²š—¹š—¶š˜ƒš—²š—æš˜†.
That is the architecture.
In š—£š—®š—æš˜ šŸ±, we go deeper into š—¢š——š—Ø š—“š—æš—¼š—¼š—ŗš—¶š—»š—“ and multiplexing and explain how multiple services are efficiently combined without losing determinism.
