Optical Supervisory Channel (OSC) in DWDM Networks
  • In DWDM systems, management signals can be transmitted using ESC (Electrical Supervisory Channel) or OSC (Optical Supervisory Channel).
  • These management signals originate from the control board of the equipment shelf.
  • They are sent through the backplane to the respective card and then transmitted as a signal.
  • When carried within the OTN overheads, the channel is referred to as ESC.
  • When transmitted as a dedicated optical signal (Layer 0) over wavelengths such as 1510 nm or 1490 nm, it is called OSC.
  • Since OSC/ESC share the same line fiber with C-band traffic, they must operate on separate wavelengths outside the C-band (commonly asked in interviews).
  • The OSC board has multiple roles:
    • Transmits management signals.
    • Processes IEEE 1588v2 clock signals for network synchronization.
    • Supports line fiber monitoring by sending test signals and analyzing reflections to assess fiber performance and quality.
  • A practical example is the AST2 board in the Huawei OSN 9800, which integrates OSC, synchronization, and fiber quality monitoring functions.
