Open RAN (ORAN) architecture, evolution & deployment - 5G
Hello All.
Please find details of my course on Open RAN:
Open RAN Architecture, O-Cloud, Intelligent Controllers (RIC), Virtualization, Orchestration, ML, MEC & 5G Deployment
Open RAN (ORAN) is a standard led by the Telcom Infra Project (TIP) and other communities such as O-RAN alliance community. Its aim is to “accelerate innovation and commercialization in RAN domain with multi-vendor interoperable products and solutions that are easy to integrate in the operator’s network and are verified for different deployment scenarios.”
Open RAN is a radio access network where hardware from any equipment supplier can be used with software, API, source code, interface etc. from other different suppliers. Shift from Proprietary to COTS (Commercial off the shelf).
Open RAN split key RAN functions among different nodes to manage different services and applications (real time and non-real time). Open RAN is also known as Disaggregated RAN. Baseband functionality is split between central unit (CU) and distributed unit (DU).
Open RAN is broadly a Software enabled Network. Open RAN enables RAN flexibility and development velocity with simultaneous reduction in capital and operating expenses through the adoption of open-source software and continuous evolution through CI/CD. Virtualization decouples infrastructure and extracts required functions (such as CU and DU) virtually. Orchestration coordinates the lifecycle of virtual network functions to realize required service (e.g., slicing).
Cloudification is an integral part of Open RAN. Cloud platform enables convenient, on demand access to shared pool of configurable resources in the radio access network through virtualization in Open RAN. Cloudification can be done for CU, DU and near real time RIC nodes.
As RAN is disaggregating and moving away from proprietary system, there is an innovation happening by leveraging machine learning (ML) to enable more efficiency as compared to conventional RAN by introducing intelligent controllers known as Radio Intelligent controllers (RIC), which can work for real and non-real time services. ML can also help to optimize the features and parameters in the network to make it more efficient. It is a part of self-organizing network feature (SON).
Software defined network (SDN) helps to enable traffic engineering for access networks.
Multi access edge computing (MEC) helps to move network resources and functions closer to the users and enable multiple emerging applications having stringent requirement of roundtrip time and processing of huge amount of data at edge.
Robust transport connectivity is prerequisite to connect disaggregated Open Radio access network.
Who this course is for:
  • Suitable for the engineers working in 5G space or planning to get into technical domain of 5G
  • Suitable for Managers working in telecom operators and planning to deploy or manage 5G networks
  • Suitable for beginners who are interested to get into telecom domain and learn new technology such as 5G and OPEN RAN
https://www.udemy.com/course/open-ran-oran-architecture-evolution-deployment-5g/
Open RAN (O-RAN) in 5G is an evolution of traditional RAN where network components are disaggregated into units like RU, DU, and CU with open and standardized interfaces, allowing operators to mix and match vendors instead of relying on a single supplier. It evolved from legacy RAN → C-RAN → vRAN to a more flexible, cloud-native architecture that also introduces the RAN Intelligent Controller (RIC) for AI/ML-based optimization. In deployment, O-RAN is being used in urban networks, private 5G, and rural coverage due to its cost efficiency and scalability, but it still faces challenges like multi-vendor interoperability, performance tuning, and integration complexity. Overall, O-RAN is a key step toward more open, intelligent, and future-ready 5G networks.
