Hello All.
Any one tried the OneCell solution from Commscope?
Hello All.
Yeah, I have worked in commScope onecell for few years ![]()
Happy to help if you need any info…
Nice!
How does it compare to Radio Dot from Ericsson?
Do you mean their spider cloud solution?
Mostly commScope radio is made for enterprise solution, which comprises radio of NGRP (Next generation radio point) or RP5K or RP 2K.
Customer need here about neutral network mostly.
Next phase will be private network.
But Ericsson radio dot solution was over expensive.
Yeah, I have worked with Ericsson AB also.
Comparatively CommScope solution is cheap and better if deployment is for enterprise or indoor.
But if you have any specific query related to OneCell solution …I am happy to help ![]()
