One Huawei Sector Keeps Dropping Calls & Data Despite Good RSRP - What Are We Missing?
Hi experts,
I’m looking for some advice from the RF community on a challenging issue I’m facing on one of the sites I’m working on.
The vendor is Huawei , and the site is running:
  • 4G: L1800 + L700
  • 3G: U850
The strange part is that the usual checks look normal - RSRP and other key RF parameters appear healthy , but one specific sector continues to experience:
  • Continuous call drops
  • Data session drops
  • Poor user experience isolated to this sector
Other sectors are behaving normally, which makes this issue even more confusing.
I have attached the alarm details observed from the site. Would appreciate any expert advice on where to focus the troubleshooting:
  • RF issue?
  • Sector hardware problem?
  • Transmission/backhaul?
  • Parameter/configuration issue?
  • Interference or hidden degradation?
Has anyone experienced a similar Huawei LTE/3G sector issue where measurements looked fine but users were still dropping?
Any troubleshooting tips, Huawei-specific checks, or past experiences would be highly appreciated. Thanks in advance!
Looking at the alarm indication, S1 points more toward a transmission/TNL instability rather than an RF coverage issue .
Since the sector is showing normal RF conditions (RSRP/SINR/RSRQ within acceptable range) but still experiencing continuous call and data drops, I would first investigate the S1 transport path . A TNL issue can cause signaling interruptions, leading to abnormal call releases and data session drops even when radio performance looks healthy.
I would suggest involving the transmission team and checking for any intermittent issues such as:
  • Packet loss / delay variation on the transport path
  • S1 link flapping or resets
  • Interface errors or congestion
  • Backhaul instability
  • VLAN/IP transport issues
From the eNodeB side, please verify the related counters, especially:
  • S1 reset/release events
  • TNL failure-related counters
  • S1 signaling failure counters
  • Call release causes (check if releases are mapped to TNL/S1 failure)
  • Data bearer release/drop counters
One thing to keep in mind: a healthy RSRP does not always mean the site is healthy end-to-end. If the S1 transport is unstable, the user impact will still appear as call drops and data interruptions.
Share the exact alarm and counters if available - it will help narrow down whether this is transport, hardware, or configuration related.
You can check following counters:
L.E-RAB.AbnormRel.TNL
L.E-RAB.AbnormRel.TNL.PreEmp
L.E-RAB.AbnormRel.TNL.Load
L.E-RAB.AbnormRel.TNL.VoIP
L.E-RAB.AbnormRel.TNL.PreEmp.VoIP
L.E-RAB.AbnormRel.TNL.Load.VoIP
L.E-RAB.AbnormRel.TNL.Other
L.E-RAB.AbnormRel.TNL.Other.VoIP
L.E-RAB.AbnormRel.TNL.QCI2
L.E-RAB.AbnormRel.TNL.QCI7
L.E-RAB.AbnormRel.TNL.GtpuError
L.E-RAB.AbnormRel.TNL.GtpuNoResp
L.E-RAB.FailEst.TNL
L.E-RAB.FailEst.TNL.DLRes
L.E-RAB.FailEst.TNL.ULRes
L.E-RAB.FailEst.TNL.VoIP
L.E-RAB.FailEst.TNL.DLRes.VoIP
L.E-RAB.FailEst.TNL.ULRes.VoIP
L.E-RAB.FailEst.TNL.Other
L.E-RAB.FailEst.TNL.Other.VoIP
L.E-RAB.FailEst.TNL.QCI2
L.E-RAB.FailEst.TNL.QCI65
L.E-RAB.FailEst.TNL.QCI69
L.E-RAB.FailEst.TNL.QCI66
L.E-RAB.FailEst.TNL.QCI70
L.E-RAB.FailEst.TNL.Other.QCI1.CBTC
L.E-RAB.FailEst.TNL.ULRes.QCI1.CBTC
L.E-RAB.FailEst.TNL.DLRes.QCI1.CBTC
L.E-RAB.FailEst.TNL.QCI1.CBTC
L.HHO.Prep.FailIn.AdmitFail.TNL.DLRes
L.HHO.Prep.FailIn.AdmitFail.TNL.ULRes
L.HHO.InterFddTdd.Prep.FailIn.AdmitFail.TNL.DLRes
L.HHO.InterFddTdd.Prep.FailIn.AdmitFail.TNL.ULRes
L.HHO.Prep.FailIn.TNL
L.E-RAB.AbnormRel.TNL.PLMN
L.E-RAB.AbnormRel.TNL.PreEmp.PLMN
L.E-RAB.AbnormRel.TNL.Load.PLMN
L.E-RAB.AbnormRel.TNL.VoIP.PLMN
L.E-RAB.AbnormRel.TNL.PreEmp.VoIP.PLMN
L.E-RAB.AbnormRel.TNL.Load.VoIP.PLMN
L.E-RAB.AbnormRel.TNL.Other.PLMN
L.E-RAB.AbnormRel.TNL.Other.VoIP.PLNM
L.E-RAB.FailEst.TNL.PLMN
L.E-RAB.FailEst.TNL.DLRes.PLMN
L.E-RAB.FailEst.TNL.ULRes.PLMN
L.E-RAB.FailEst.TNL.VoIP.PLMN
L.E-RAB.FailEst.TNL.DLRes.VoIP.PLMN
L.E-RAB.FailEst.TNL.ULRes.VoIP.PLMN
L.E-RAB.FailEst.TNL.Other.PLMN
L.E-RAB.FailEst.TNL.Other.VoIP.PLMN
L.HHO.Prep.FailOut.TNL
L.HHO.X2.Prep.FailOut.TNL
L.NsaDc.MenbTrig.SgNB.AbnormRel.TNL
L.NsaDc.SCG.Change.Failure.TNL
L.NB.E-RAB.FailEst.TNL
L.NB.E-RAB.AbnormRel.TNL
L.E-RAB.AbnormRel.TNL.QCI65
L.E-RAB.AbnormRel.TNL.QCI69
L.E-RAB.AbnormRel.TNL.QCI66
L.E-RAB.AbnormRel.TNL.QCI70
L.E-RAB.AbnormRel.TNL.GtpuError.VoIP
L.E-RAB.AbnormRel.TNL.GtpuNoResp.VoIP
But again: if only one sector is experiencing issues while the others are fine, it’s unlikely to be caused by S1, since S1 would affect the entire site.
Check the connection between the MME and the router, and verify the eNB-to-MME configuration.
Adjust A4 value.
