Numerology Effects in 5G NR
With smaller SCS, system is more tolerable to the effects of multi path delay spread. Suggested for Lower frequency range with requirement of wide coverage area. -
Larger SCS leads to smaller slot length thus enabling shorter TTIs. Its beneficial for fast transmission turn around time (low latency transmission). Suggested for higher frequency range. -
Larger SCS is advantageous in terms of lower sensitivity to phase noise. -
SCS selection for a frequency band always a tradeoff task and depends on the kind of deployment considering above factors. -
Also, mini slot provides the viable solution to low latency transmission irrespective of sub carrier Spacing.
Correlation between Numerology & other frame entity is shown in slide for easy remembering.
LinkedIn: Pawan Kumar Choudhary on LinkedIn: #5g #nr #lte #rftechpoint
