Nokia CA deactivation during Volte calls
Is there any feature that deactivate CA during Volte calls?Nokia vendor
basically VOLTE calls are mapped to the primary cells no matter what SCC do you have, the VoIP will be mapped to the primary.
what is the real reason behind your request.
That’s ok. Teh real reason is less signaling, measurement events…power in a case of CA for uplink…
Thanks
