Dear RF/BSS Engineers,
While working with the Ericsson dump, you might find it challenging to parse the XML file efficiently. Nonetheless, I have created a free tool called “Nexa” that will provide you with a set of functions that make it pleasant to deal with such dumps. Nexa can do the following:
- Parse Ericsson XML files.
- Compare XML dumps and highlight the differences.
- Plot sites/cells in KML
- Generate Bulk-configuration MML files to match the reference XML file.
- Generate Bulk-configuration MML for the parsed XMLs.
I hope you find it useful. I look forward to your comments and feedback.
** It’s an OFFLINE tool, and needs no subscription/logging/…
