New QGIS Skill: 5G Hotspot DL Throughput Benchmarking
This February, I built a 5G DL Throughput Benchmark for 100 hotspots using QGIS — and here’s the workflow that made it possible:
:white_check_mark: Grid Creation — Defined uniform measurement zones across all hotspots
:white_check_mark: Voronoi Polygons — Mapped each hotspot’s coverage influence area
:white_check_mark: Join Attributes — Attached DL throughput KPIs to each polygon
:white_check_mark: Dissolve — Grouped zones by performance level
:white_check_mark: Polygon Difference — Highlighted exactly where improvements occurred after optimization
The result: a clear, map-based before & after view of 5G DL Throughput improvements — no guesswork, just spatial proof. :satellite_antenna:
