Multi-RAT Worst-Cell Detector
Dear All
You can download the trial (10 days) of powerfull RF tool that can screen your network over 6 months -1 one year through handling big data for detecting the worst cells or chronic ones with combination of main KPIs using ML for 2G,3G,4G, 5G networks Huawei. PM for license after expire
It ingests Huawei daily KPI exports across 2G, 3G, 4G, and 5G — automatically matches every KPI to the right catalogue per technology — and runs three layers of detection in parallel:
→ Statistical trend analysis: is this cell’s recent window worse than its own baseline, with statistical significance?
→ Isolation Forest ML: is this cell’s joint KPI signature anomalous compared to its peers?
→ Change-point detection: when did the degradation actually start?
find below video help on linkedin
BR
Are you sending a virus? :slight_smile: How about the required license? Which files shall we upload? can you please clarify these queries? Thanks for sharing.
For sure no virus or any malware, the warning that appearing at the installation step just I am not sign my application with window certificate.
By default, you have 10 days trial for testing all features. Once 10 expire the window of license will appear with your fingerprint ID. If you see still useful for your work then send private message with fingerprint ID.
