Dear Experts,
I have one query regarding field observation of NR and LTE TF propagation…
We have L2300 anchor and N3500 secondary.
Near the site below the antenna, RSRP difference between the 2 is around 12 dB, i.e. NR is 12 dB weaker.
But at the cell edge, difference between RSRP of NR and LTE is just 2-3 dB.
As we know, M3500 have more free space losses and attenuation losses than L2300, due to higher frequency, it should have attenuated more.
But we observed that L2300 attenuated more at cell edge, and difference between the 2 has reduced
This is strange to me. Can anyone explain why this would happen?
Ssb are transmitted in one direction.
8 of them will cover the whole sector.
Or 4 or 64.
This is why we have 64 TX on one antenna.
You can’t expect an ssb to be generated by only one TX.
Lets say we have to cover 120 degree.
With 8 beam, I can perform beam forming where each beam will cover 120/8 angle.
So whole sector will get covered.
Same with 4 beam.
Then with only one ssb, how to cover whole sector every 20 ms?
