Modulation in 5G NR – Same Symbol Duration, More Bits per Symbol
In 5G NR, the symbol duration remains the same regardless of the modulation scheme. The difference lies in how many bits each symbol carries:
:small_blue_diamond: QPSK → 2 bits/symbol
:small_blue_diamond: 16-QAM → 4 bits/symbol
:small_blue_diamond: 64-QAM → 6 bits/symbol
:small_blue_diamond: 256-QAM → 8 bits/symbol
Higher-order modulation increases spectral efficiency, Transport Block Size (TBS), and throughput—but it also requires a higher SINR for reliable decoding.
:blue_book: A simple infographic explaining the relationship between Modulation Order, Symbol Duration, Spectral Efficiency, and Transport Block Size (TBS).
