MO / Parameters to define / create nodes in SA / NSA configuration
Experts.
Any template to define which MO / Parameters are applicable to define / create in Ericsson node towards Nokia node for NBR definition in SA/NSA configuration?
Good afternoon @arora.
I haven’t configured yet E/// → Nokia, but probably for 5G NSA should be the same way as E/// → E///.
Where you need to define the Nokia 5G Neighbor Node with the proper information (gnbid, ipaddress…) in the E/// 4G Node and the E/// 5G Node.
In the picture above we first define the 4G->5G definition and then the 5G->5G relation, because they need to be done paired when NSA.
Some of the parameters are Mandatory some are just optional.
Hope this works the same way E/// to Nokia.
Thanks Fredy , much appreciated!
(Although I have most of these in my list).
I was looking more into on feature, node and FDD level.
Please let me know if you aware any of these.
You’re Welcome!
I do not know which features may be needed but I will do a search and if I found something useful I’ll let you know.
Other experts can suggest too.
Hello can u help me for NSA to SA+NSA Conversion in Nokia . Currently site running in NSA and we want to convert SA+NSA .
