Measurement Report In Ericsson eNodeB
Yes, I can confirm reportConfigB2GeranId 1 belongs to the cell under test and cell I edited is the serving cell during testing.
Share: UE trace / cell trace
Can I use PMIC of ENM to fetch the cell trace?
You can use ENM PMIC if the cell/UE trace you need is available there. Fetch the trace for the test call and analyse the relevant portion showing the B2 MeasurementReport and the subsequent HO Required/SRVCC event. You need the UE’s serving RSRP when B2 is reported and the timing between the B2 report and HO Required.
