LTE vs 5G NR: Physical Layer Differences
As wireless networks evolve, understanding the physical layer (PHY) differences between LTE and 5G New Radio (NR) is essential for engineers and tech enthusiasts alike.
Here are some key distinctions:
  1. Waveform and Access:
    • LTE uses OFDMA (DL) and SC-FDMA (UL).
    • 5G NR uses OFDMA in both uplink and downlink, with optional DFT-s-OFDM for UL (mainly for low PAPR use cases).
  2. Subcarrier Spacing:
    • LTE uses a fixed 15 kHz subcarrier spacing.
    • 5G NR introduces scalable numerology: 15, 30, 60, 120, 240 kHz — supporting low to mmWave bands and low-latency use cases.
  3. Frame Structure:
    • LTE has a rigid frame structure: 10 ms frame, 1 ms subframe.
    • 5G NR is more flexible: same 10 ms frame but subframe and slot durations scale with numerology.
  4. Channel Coding:
    • LTE uses Turbo coding for data and tail-biting convolutional codes for control.
    • 5G NR uses LDPC for data and Polar codes for control — enabling higher throughput and better error correction.
  5. Massive MIMO & Beamforming:
    • LTE supports MIMO but with limited spatial flexibility.
    • 5G NR is built for Massive MIMO and advanced beamforming, enabling precise spatial multiplexing and extended coverage.
  6. Carrier Bandwidth:
    • LTE supports up to 20 MHz per carrier.
    • 5G NR supports up to 100 MHz (sub-6 GHz) and up to 400 MHz (mmWave), enabling gigabit speeds.
In essence, 5G NR is designed for flexibility, scalability, and efficiency, addressing a wide variety of use cases — from IoT and enhanced mobile broadband to ultra-reliable low-latency communication (URLLC).
