LTE Signal Strength vs Signal Quality: Understanding RSRP, RSRQ, and RSSI
When troubleshooting LTE networks or reviewing drive test logs, three radio measurements frequently come into focus: RSRP, RSRQ, and RSSI. These KPIs are widely used to evaluate coverage, signal quality, and overall network performance.
While the concepts are familiar to most RF engineers, interpreting them together is often where the real challenge begins. A cell may show excellent RSRP values, yet users can still experience poor throughput due to interference, congestion, or degraded signal quality reflected in RSRQ.
Key LTE Measurements
  • RSRP (Reference Signal Received Power): Indicates the strength of the LTE reference signal and is commonly used to assess coverage.
  • RSRQ (Reference Signal Received Quality): Reflects signal quality and helps identify interference and network loading issues.
  • RSSI (Received Signal Strength Indicator): Represents the total received power, including serving cell signals, neighboring cells, and noise.
Looking at these KPIs together provides a much clearer understanding of LTE radio conditions than analyzing any single metric alone.
Why It Matters
:check_mark: Faster troubleshooting of coverage and quality issues
:check_mark: Better understanding of LTE radio behavior
:check_mark: Useful for drive testing and network optimization
:check_mark: Helps telecom professionals interpret field measurements more effectively
For those who work regularly with LTE radio KPIs, this LTE RSRP, RSRQ, and RSSI Calculator can be a useful reference for quick calculations and learning:
:backhand_index_pointing_right: https://www.linkedin.com/pulse/lte-rsrp-rsrq-rssi-calculator-techlte-world-t0dlc/
How do you typically prioritize RSRP, RSRQ, and RSSI during LTE troubleshooting? Do you rely more on signal quality metrics than signal strength when investigating user experience issues?
