Dear Experts,
I do need your kind recommendation and experince on Multi layer Balancing,
Sample Scenario:
there are 4 Layer of LTE in the Network (L18/L21/L26-1/L26-2)
MLB Enabled on both PRB & User
MBCS is already set unsuccessful and rolled backed
Q1: we have diffrent Qualty on each band what should be the target parameter to maximize the Sector UE Throughput
A.PRB Based balancing B.User Based Balancing C.Throughput Based Balancing D.any other possible target(mention plz)
Q2:what is the best Load Sharing solution to achive the target:
1.Using MLB B.Using Mobility Parameter C.RSRQ Based HO D.any other possible
