Is there a specific counter in Ericsson LTE that tracks failures caused by a single UE?
You should typically check using TMA or, preferably, from the core side, as the clear codes provide valuable information.
However, if you have the BTS and the time window for the failures, TMA is the best tool.
Create a cell trace and parse it using tools like Aexio Xeus.
It will provide the MSISDN, allowing you to map the mobile type using the TAC code list.
Thanks!
Can TMA open Ericsson CTR files?
Is it an open-source tool?
Is Aexio Xeus still available?
Actix can open Ericsson CTR files.
I’m not sure. I used it a few years ago, up until 2020.
I think Infovista acquired the company, but I don’t know if the software name is still in use or has been replaced. ![]()
TMA is an Ericsson tool for monitoring and tracking from the radio side.
I don’t think it can parse CTR files from another tool, as it uses its own format.
