If you’ve ever had someone ask “isn’t LTE just 4G?” and found yourself struggling to give a clean answer- you’re not alone. The 3G → 4G → LTE → LTE-A naming mess has confused even people working in the industry, mostly because of how carriers marketed “4G LTE” long before LTE technically met the ITU’s IMT-Advanced requirements.
I put together a resource that walks through this from the ground up- starting with the basic “what is LTE vs 4G” distinction, then going deep into the actual architecture and protocol layers for anyone working with RF, core network, or protocol stack topics day to day.
What’s covered:
- LTE vs true 4G (IMT-Advanced) — the actual technical distinction behind the marketing
- EPS architecture and interfaces (S1, X2)
- Protocol stack — RRC, PDCP, RLC, MAC layers
- Physical layer procedures — PSS/SSS, RACH, PRACH preamble generation
- Call flows — attach procedure, handovers (X2/S1), RLF
- Carrier Aggregation, MIMO, scheduling, HARQ, DRX
- Measurement reporting, SIB/MIB, paging
It’s structured so beginners can start with the fundamentals and progressively move into the deeper procedural/architecture stuff- so it works whether you’re prepping for interviews, brushing up on fundamentals, or just want a reference to link back to.
Full breakdown here
: LTE and LTE Advanced - 4G Wireless Technology
