Hello Telecom Experts,
I am currently working on an Ericsson BBU and I need your support regarding ACL configuration for the OAM access plan .
I already attempted the configuration, but I am facing an issue:
I created an ACL with PERMIT rules for the ENM access IP address.
The ACL itself is in permit mode.
However, once I apply this ACL to the OAM access interface , I completely lose access to the BBU , even though the source IP should be permitted.
I would like to ask:
Are there any common pitfalls with ACLs on Ericsson BBUs for OAM access?
Is there a recommended step-by-step procedure (MOP) to avoid losing connectivity?
Should additional rules (e.g. default permit, return traffic, management IPs, protocols) be explicitly defined?
Is there any specific order or dependency when applying ACLs on OAM interfaces?
Any guidance, best practices, or examples would be highly appreciated.
Hi, @Amine_Hechiche , first thing is brmfailsafe activation:
set BrmFailsafeBackup timeoutLength 600
acc BrmFailsafeBackup activate
RBS will automatically rollback on CV if you loose OAM.
Second thing is configuration entries for both directions - in and out:
crn Transport=1,Router=oam,AclIpv4=ingress,AclEntryIpv4=enm_in
action 0
priority 10 # priority
addrDst 192.168.0.1/30 # RBS oam address
addrSrc 10.10.10.0/24 # ENM subnetwork
end
crn Transport=1,Router=oam,AclIpv4=egress,AclEntryIpv4=enm_out
action 0
priority 11
addrDst 10.10.10.0/24 # ENM subnetwork
addrSrc 192.168.0.1/30 # RBS oam address
end
Attach ACL to interface:
set Transport=1,Router=oam,InterfaceIPv4=1 aclEgress Transport=1,Router=oam,AclIpv4=egress
set Transport=1,Router=oam,InterfaceIPv4=1 aclIngress Transport=1,Router=oam,AclIpv4=ingress
If all above is OK, then deactivate brmfailsafe:
acc BrmFailsafeBackup deactivate
Hello Míster @vlr9999
Thanks for your reply.
Can you please spicify which one should be used as permit ?
Should we add dent ACL ?
BR.
vlr9999
February 2, 2026, 10:26am
4
@Amine_Hechiche ,
action 0 # PERMIT
action 1 # DENY
You can choose from 2 strategies:
Add entries with PERMIT action - then packets from other subnetworks are dropped.
Add default entry with PERMIT and other entries with DENY action.
And/or there is available filter by IP protocol.
Thanks ! I will test that and come back
Best regards sincerly !
