LLM-Shark - an AI tool to analyze signaling in pcap format
We typically use Wireshark to analyze raw signaling (in pcap format)
Now we can leverage AI to analyze raw signaling—simply pose your questions in natural language
AI can provide you with analysis and diagnostic conclusions
You can review AI’s thought process
You can view AI-generated signaling sequence diagrams
Provide your requirements or questions regarding AI’s response, and AI can continue to refine its answer
Generate a new, more accurate and complete sequence diagram
And update the analysis and diagnostic conclusions
The tool supports dozens of languages and is compatible with OpenAI-compatible LLM service APIs
The free version provides a daily quota of 3 signaling pcap files for analysis, with monthly/annual subscription plans available for upgrade
LLM-Shark is now available on the Microsoft Store. Download and install it directly through the following link:
ms-windows-store://pdp/?productid=9NJQ6N01CF65
