Do you know the exact DRB setting that can be used to fix latency on the network
There isn’t one exact DRB setting that universally fixes network latency. DRB (Data Radio Bearer) configurations depend on the network type, traffic profile, QoS parameters, and operator setup. Latency issues are usually related to congestion, QoS priority, bandwidth limits, or routing — not just a single DRB value. Proper network analysis is required.
