Is there any way to block the QCI2 service without blocking QCI1?
One way is to disable qci2 at eNB.
Which parameter?
eNB configuration mgmt tool, it must have enable / disable option.
Each vendor have different tool.
Just curious… if you disable QCI2, how conversational video will happen in your network?
On which QCI?
And more important: with what QoS since you disabled QCI2?
Due to some insurgency issue, government has asked for barring both Data and Video call.
For Ericsson?
Remove the configuration from the user profile in HSS.
