Is there any parameter for congestion - handover to nbr cell - in Nokia 2G?
What do you mean by congestion - handover?
If cell is congested, means call attempts are more than its capacity - then it should handover to nbr cells.
Actually it is available in Nortel network, where congested cell can handover the call to a particular cell.
Need to know if any similar configuration available for NOKIA.
Also is it possible to configure a TCH channel as dynamic SDCCH in case of SD blocking?
Yes you have it
Directed retry procedure.
You have to enable it under BSC.
BTS level
drInUse
drMethod
In the ADCE you can set the drThreshold
Normally this functionality is enabled by default.
Check it at Cell level (BTS)
No, it is not.
Ok, thanks.
I think this is available in HUAWEI network.
Have you tried half rate traffic shifting?
Try BSS21113, BTS overload control if ur sw supports. and half rate based on cell load for 2G.
Can it done site wise?
Didn’t try it yet. What is the exact parameter in Nokia BSC?
It’s cell wise.
Yes try traffic based Handover (TRHO), when source cell is congested & neighbour is available with (Condition for capacity & coverage thresholds), on-going call will be handed over to neighbour cell.
