Hello Atoll Experts.
Is there any cell range difference between 2x2 and 4x4 simulation in Atoll?
For TDD.
For TDD.
It should have difference logically and practically, so Atoll should also give same picture.
This is one of the issues I faced in Atoll; changing the number of TX/RX antennas wont impact the coverage at all; I think there is a trick I might ignore about power distribution; for my case; I just make sure that the reference signal is matching my scenario for 2x2 or 4x4 by setting the max trasmission power.
As mentioned above, if you are running RSRP coverage, then set the cell parameter RS power according to what you have in network. For example sometimes if you are running 2x2 on full power and then you switch to 4x4 you might lose 3dB on RS, thus decreasing your predicted coverage, which on other hand can be in network compensated by RS power boost etc.
