Is CIO value defined against NBR applicable for both RSRP/RSRQ?
Samsung System
Samsung System
As per 3GPP yes, it’s applicable.
Will it not depend on triggerquantity?
Yes, correct.
Thanks!
If trigger quantity will be RSRQ based then same CIO Value will work?
Yes, even with RS-SINR as well.
CIO Value range is - 24 dB to + 24 dB, while RSRQ range is -3 dB to -19.5 dB.
Ideally CIO range for RSRQ must be in between -3 to 19.5 dB.
