Q. Is a telecom cell physical?
a) No. Cell is a radio frequency.
b) Yes.
c) It is a logical configuration mapped to a physical sector.
d) Only physical if using massive MIMO.
Check 🔎
Correct answer: Letter a.
In telecom, a cell is a logical radio configuration (frequency, PCI, etc.) used to serve users in a specific coverage area. While it is mapped to a physical antenna or sector, the cell itself is not physical — it represents a radio frequency resource.
a)
→ Correct. A cell is defined by radio parameters like frequency, bandwidth, and identifiers — not a tangible object.
b)
Yes.
→ Incorrect. The antenna or sector is physical, but the cell is a logical concept tied to it.
c)
→ Incorrect. While true in part, the cell itself remains logical — its definition lies in radio settings, not hardware.
d)
→ Incorrect. Massive MIMO enhances signal behavior, but does not make the cell itself physical.
