Hi All,
In which release will be introduced 1024 QAM?
For 4G and 5G?
For 4G you can check IE cqi_reportconfig_v1530 there u can configure 1024 qam.
I used it.
It’s r15.
For 5G under pdsch_config setup IE there is parameter mcs table where I find only 2 options, i.e. 256 qam and qam 64 low SE.
Seems 1024qam not there for 5g as of now.
Same seen for uplink as well under pusch_config setup.
