In which MO can we find IP for GNodeB, Huawei vendor?
MML command: LST DEVIP
Thanks.
And in the dump NBI or GExport?
Dump from Huawei OSS.
I use configuration report management to get dumps.
No problem, I will try to talk with Huawei support.
Thanks!
You can try NE Backup.
And you will get *.xml file.
I usually import it to OMSTAR.
Thanks All.
I use BODA to parse the raw dump, and get all MO as CSV files.
But I didn’t find the gNodeB IP address.
For example DEVIP have all IP address for eNodeB but not have gNodeB IP.
